도움말
Alienware M15x RAM Replacement
진행 중
진행 중
해당 안내서는 작업중 입니다. 최근 변경사항을 보려면 정기적으로 새로고침하여 주십시오!
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
  • 작성자: Gabe
  • 예상 시간 5 분
  • 난이도: 아주 쉬움
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
단계 1 RAM  ¶
First, take off the battery by moving the latch to the left and pulling it up.
단계 1 RAM  ¶
  • First, take off the battery by moving the latch to the left and pulling it up.
단계 2  ¶
Then unscrew the two Phillips screws. Pull the cover down, then up, revealing the internals Pull the cover down, then up, revealing the internals
단계 2  ¶
  • Then unscrew the two Phillips screws.
  • Pull the cover down, then up, revealing the internals
단계 3  ¶
Unscrew the two screws indicated
단계 3  ¶
  • Unscrew the two screws indicated
단계 4  ¶
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
단계 4  ¶
  • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
