도움말
2003-2004 Land Rover Range Rover Backup Camera Upgrade
더 많은 이미지가 필요함
더 많은 이미지가 필요함
몇몇 추가 이미지는 해당 안내서의 절차를 아주 명백하게 만들 것입니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
How to install a reverse backup camera that operates automatically when you put your Range Rover in reverse
단계 1 Range Rover Backup Camera  ¶
In the Range Rover with the television module you can easily connect a reverse backup camera providing you with full backup camera function on your Range Rover Display Car will need to be equipped with BMW TV video module.  If not equipped you will need to retrofit Range Rover Television module.  Google Search: retrofit range rover television module --- for available options. or go to www.roverupgrades.com
  • In the Range Rover with the television module you can easily connect a reverse backup camera providing you with full backup camera function on your Range Rover Display
  • Car will need to be equipped with BMW TV video module. If not equipped you will need to retrofit Range Rover Television module. Google Search: retrofit range rover television module --- for available options. or go to www.roverupgrades.com
  • Backup Camera Automatic Switching Requires a reverse camera switching module kit, and a NTSC reverse camera mounted in any location desired.
단계 2  ¶
Connect Switching module BLUE wire into Pin 17 on the BLUE plug on your TV video module. Slide the Black Locking lever to the side on your TV video module to release the Blue plug. Remove the cover of the blue plug by gently lifting up on the cover locking tab with a small screw driver.  Then slide the cover off
단계 2  ¶
  • Connect Switching module BLUE wire into Pin 17 on the BLUE plug on your TV video module.
  • Slide the Black Locking lever to the side on your TV video module to release the Blue plug.
  • Remove the cover of the blue plug by gently lifting up on the cover locking tab with a small screw driver. Then slide the cover off
  • Insert the BLUE pin into the Pin location 17. If you look closely you will see the number 18 on the black part of the plug. Pin 17 would be the next pin location over
  • PLEASE NOTE: IF your camera switch module has an extra wire in the center marked 87a it is NOT connected anywhere. This extra wire, if present, is not used.
단계 3  ¶
Connect the RCA connectors that come with the Reversing Camera Switching module to the white plug. Remove the cover of the white plug as before. Insert the Colored wire on the RCA Plug into the White plug Pin location 13
단계 3  ¶
  • Connect the RCA connectors that come with the Reversing Camera Switching module to the white plug.
  • Remove the cover of the white plug as before.
  • Insert the Colored wire on the RCA Plug into the White plug Pin location 13
  • Insert the BLACK wire on the RCA Plug into the White plug Pin location 14
  • See wiring diagram for reference
단계 4  ¶
Install your Reversing Camera to the proper specifications of the Camera supplier. Connect the RCA Camera Output (MALE RCA) into the Reversing Camera Switching module RCA Video input cable (FEMALE RCA)
단계 4  ¶
  • Install your Reversing Camera to the proper specifications of the Camera supplier.
  • Connect the RCA Camera Output (MALE RCA) into the Reversing Camera Switching module RCA Video input cable (FEMALE RCA)
