메인 콘텐츠로 스킵하기
도움말
Samsung Galaxy S III i8190 mini Display + Touch Screen Replacement
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Here we are! We are going to know how to replace the assembly of display+touch screen
  • 작성자: Jaime
  • 예상 시간 30 분 - 1 시간
  • 난이도: 보통
단계 1 Display + Touch Screen  ¶
Here we have the Samsung Galaxy S3 mini with the LCD broken. The touch works fine, but its easier to replace the entire assy. First of all, remove the battery door, then the battery.... Then, unscrew all the screw from the bottom side. NOTE:All the screws has the same lenght
  • Here we have the Samsung Galaxy S3 mini with the LCD broken. The touch works fine, but its easier to replace the entire assy.
  • First of all, remove the battery door, then the battery....
  • Then, unscrew all the screw from the bottom side. NOTE:All the screws has the same lenght
단계 2  ¶
Now, with a flat screwdriver or the plastic triangle, separate the rear case from the front case. Here we have the call speaker. Its glued to the front, so we have to release it or desolder the 2 knobs on the flex cable. Here we have the call speaker. Its glued to the front, so we have to release it or desolder the 2 knobs on the flex cable.
단계 2  ¶
  • Now, with a flat screwdriver or the plastic triangle, separate the rear case from the front case.
  • Here we have the call speaker. Its glued to the front, so we have to release it or desolder the 2 knobs on the flex cable.
단계 3  ¶
Remove the volume and power buttons. Release the lower buttons and MicroSD connectors. Release the lower buttons and MicroSD connectors.
단계 3  ¶
  • Remove the volume and power buttons.
  • Release the lower buttons and MicroSD connectors.
단계 4  ¶
Now, lift from the right side the board, and be careful, below is the LCD connector. It´s turn to the HOT STATION. If you don´t have one of this, you can do it with a Hairdryer or a Heat gun
단계 4  ¶
  • Now, lift from the right side the board, and be careful, below is the LCD connector.
  • It´s turn to the HOT STATION. If you don´t have one of this, you can do it with a Hairdryer or a Heat gun
  • I don´t have any photo of the proccess, so I´m sorry for that. You must heat all the LCD area, and with special attention on the top and bottom areas.
  • Please be careful with the 2 lower buttons, they have this orange flat cable!!
  • As you can see, the LCD is totally destroyed, but it was broken before, so...
단계 5  ¶
Now, you can see that the touch screen were damaged too, so this is why I have purchased the whole unit assy. PLEASE!! DON´T remove these adhesive tapes! They are neccessary for the new module (that doen´t have double sided tape ) PLEASE!! DON´T remove these adhesive tapes! They are neccessary for the new module (that doen´t have double sided tape )
단계 5  ¶
  • Now, you can see that the touch screen were damaged too, so this is why I have purchased the whole unit assy.
  • PLEASE!! DON´T remove these adhesive tapes! They are neccessary for the new module (that doen´t have double sided tape )
단계 6  ¶
Now, place the new module on the chassis, and be careful with the flex cables. To assembly all togheter, do the steps backwards, and don´t forget to place the volume and power up buttons! Remember to put back the speaker
단계 6  ¶
  • Now, place the new module on the chassis, and be careful with the flex cables.
  • To assembly all togheter, do the steps backwards, and don´t forget to place the volume and power up buttons!
  • Remember to put back the speaker
단계 7  ¶
Reconnect all the connectors to the main board, place the rear case, and tight all the screws! YOU DID IT!!
단계 7  ¶
  • Reconnect all the connectors to the main board, place the rear case, and tight all the screws!
  • YOU DID IT!!
