메인 콘텐츠로 스킵하기
도움말
Plunger and O-ring Replacement Guide
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
잘게 썰기
잘게 썰기
해당 안내서의 단계들은 분할되어 전제 조건 안내서들로 만들어져야 합니다.
This guide details the replacement of the O-ring and Plunger in the Nerf N-Strike Nite Finder.
If your Nerf Blaster latches and releases when you pull the trigger, but doesn't fire the dart, the O-ring might be ripped and need replacing. This guide will show you how to disassemble your Nite Finder so that you can replace the O-ring and the plunger.
==Caution==
Be aware of springs under compression. Take care so these small parts do not fly off the blaster and get lost.
단계 1 Plunger and O-ring  ¶
Place the blaster upside down on the table, and remove the screw in the bottom of the handle
  • Place the blaster upside down on the table, and remove the screw in the bottom of the handle
  • Remove the battery door and take the batteries out.
단계 2  ¶
Set the blaster on its side with the screws facing up (the blaster will be placed on its left side).  Remove all 14 phillips head, 8.2 mm screws and set them aside. Lift the side of the blaster off exposing its internal parts. Lift the side of the blaster off exposing its internal parts.
단계 2  ¶
  • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
  • Lift the side of the blaster off exposing its internal parts.
단계 3  ¶
Remove the two phillips head, 8.2 mm screws holding the barrel in place.
단계 3  ¶
  • Remove the two phillips head, 8.2 mm screws holding the barrel in place.
단계 4  ¶
Lift the barrel and plunger strait up being carful to not lose the locking spring. Pull the plunger out of the barrel
단계 4  ¶
  • Lift the barrel and plunger strait up being carful to not lose the locking spring.
  • Pull the plunger out of the barrel
단계 5  ¶
At this point you will be able to tell whether the O-ring has failed or if the plunger has broken.
단계 5  ¶
  • At this point you will be able to tell whether the O-ring has failed or if the plunger has broken.
  • If the O-ring has failed, simply buy a replacement O-ring of appropriate size from a hardware store and slip it over the end of the plunger.
  • If the plunger has broken see step 6
단계 6  ¶
Attempting to glue the plunger will most likely result in a bad O-ring seal causing the blaster to not function correctly.
단계 6  ¶
  • Attempting to glue the plunger will most likely result in a bad O-ring seal causing the blaster to not function correctly.
  • The best course of action would be to obtain an new plunger and replace it.
  • Be sure to put the locking mechanism on in the correct orientation.
