메인 콘텐츠로 스킵하기
도움말
HP Media Center 876x Video Card Replacement
글머리 기호!
글머리 기호!
더 나은 마크업 및 글머리 기호 색/형식 조정은 해당 안내서를 더욱 깔끔하게 만들것 입니다!
This guide will show you how to remove the internal video card.
The video card is instrumental in the visualization of data by the HP Media Center 876x system. If the images on screen are distorted, of bad quality, or will not appear at all, the video card may require replacement.
단계 1 Video Card  ¶
Identify the video card (the green card nearest to the fan casing in the bottom left hand corner of the tower).
단계 1 Video Card  ¶
  • Identify the video card (the green card nearest to the fan casing in the bottom left hand corner of the tower).
단계 2  ¶
Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the video card to its mount.
단계 2  ¶
  • Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the video card to its mount.
단계 3  ¶
Pull the video card vertically out of its port. Pull the video card vertically out of its port.
단계 3  ¶
  • Pull the video card vertically out of its port.
