메인 콘텐츠로 스킵하기
도움말
Toshiba Satellite L305-S5875 LCD Screen Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
This guide will help show you how to replace a damaged or malfunctioning LCD screen for the Toshiba Satellite L305-S5875 model laptop.
  • 작성자: Joshua Lessard
  • 예상 시간 30 - 35 분
  • 난이도: 보통
Welcome to the Toshiba Satellite L305-S5875 LCD Screen Replacement guide page. The ultimate goal of this page is to show you how to replace the 15.4" LCD screen on your Toshiba Satellite laptop. This guide will go step by step in explaining how to work your way to the screen, and then how to replace the screen once you're there. This guide uses both visual and written instructions to help you replace your old damaged screen with a brand new one.
단계 1 LCD Screen  ¶
Open the laptop so that you can see the screen.
단계 1 LCD Screen  ¶
  • Open the laptop so that you can see the screen.
단계 2  ¶
Remove the four rubber inserts from the four corners of the screen. Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
단계 2  ¶
  • Remove the four rubber inserts from the four corners of the screen.
  • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
단계 3  ¶
Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop. Gently pull the back panel approximately 1 inch away from the screen. Warning: Following step will detach screen from casing. Use caution.
단계 3  ¶
  • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
  • Gently pull the back panel approximately 1 inch away from the screen.
  • Warning: Following step will detach screen from casing. Use caution.
  • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
단계 4  ¶
Lay screen down on keyboard. On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present. Carefully remove the ribbon cable by pulling it out of it's socket.
단계 4  ¶
  • Lay screen down on keyboard.
  • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
  • Carefully remove the ribbon cable by pulling it out of it's socket.
단계 5  ¶
At the bottom of the screen, locate the pink and white wires. Unplug the connector from the circuit board by gently pulling it out. Unplug the connector from the circuit board by gently pulling it out.
단계 5  ¶
  • At the bottom of the screen, locate the pink and white wires.
  • Unplug the connector from the circuit board by gently pulling it out.
단계 6  ¶
Congratulations, you have just removed your screen!
단계 6  ¶
  • Congratulations, you have just removed your screen!
