메인 콘텐츠로 스킵하기
도움말
Samsung Portable Dualband Tri-Mode Keypad Replacement
일관성 없는 이미지
일관성 없는 이미지
해당 안내서의 이미지를 전제 조건들과 더욱 일관성 있게 업데이트하는 것은 안내서의 멋짐이 향상될 것입니다.
Use this repair guide to replace the keypad on a Samsung Portable Dualband Tri-Mode.
  • 작성자: Barbara
  • 예상 시간 5 - 7 분
  • 난이도: 보통
If the keypad buttons are not responding or are functioning in a way that is different from their intended purpose, then it is possible that the keypad may be damaged. This guide shows how to check the keypad and, if necessary, replace it.
섹션
단계 1 Keypad  ¶
Remove the gray keypad from the phone by peeling it back. Remove the gray keypad from the phone by peeling it back. Remove the gray keypad from the phone by peeling it back.
단계 1 Keypad  ¶
  • Remove the gray keypad from the phone by peeling it back.
단계 2  ¶
Remove the black keypad from the phone casing. Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
단계 2  ¶
  • Remove the black keypad from the phone casing.
  • Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
