도움말
Motorola Talkabout FV700R Speaker Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
This guide gives instructions on replacing a faulty speaker in the two-way radio.
  • 작성자: Kayla Brennan
  • 예상 시간 5 - 15 분
  • 난이도: 어려움
The two way radio speaker is responsible for broadcasting the signal received, making it a very important part. Follow the steps below to properly replace the speaker of the radio.
섹션
단계 1 Speaker  ¶
To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push. The speaker is glued to the front faceplate, so it may take some force to remove the speaker. The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
단계 1 Speaker  ¶
  • To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
  • The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
단계 2  ¶
Now the circuit board can be removed from the back faceplate. To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached. To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
단계 2  ¶
  • Now the circuit board can be removed from the back faceplate.
  • To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
단계 3  ¶
Observe the orientation of the speaker as it is removed, so that the new speaker can be installed to face the same way as the old one that you are removing.
단계 3  ¶
  • Observe the orientation of the speaker as it is removed, so that the new speaker can be installed to face the same way as the old one that you are removing.
  • You should end up with just the circuit board and speaker, as seen in the picture.
단계 4  ¶
Remove the wires connecting the speaker to the circuit board with a soldering iron.
단계 4  ¶
  • Remove the wires connecting the speaker to the circuit board with a soldering iron.
  • The new speaker wires can then be connected to the circuitboard with a soldering iron.
  • Be careful when working with a soldering iron, as it can easily cause burns.
  • Make sure the new speaker is connected in the same orientation as the old speaker.
