도움말
Disassembling Snapfon ez One LCD Screen
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
헷갈리는 텍스트
헷갈리는 텍스트
해당 안내서의 어떤 텍스트는 헷갈리며, 중복되었거나 주제에서 벗어났습니다. 편집하여 명확하게 하여 주십시오!
This guide will allow the user to remove and replace the LCD screen if the screen is broken.
  • 작성자: John Bender
  • 예상 시간 15 - 30 분
  • 난이도: 어려움
The LCD screen is the component of the phone that allows the user to see the oututs from the circuit board once the actions have been converted interally inside the phone from the users input.
단계 1 Pry the screen back  ¶
Using the opening tools, pry the LED screen back to give access to the connecting ribbon cable. The LED screen is connected to the mother board with light adhesive which can easily be separated. The LED screen is connected to the mother board with light adhesive which can easily be separated.
  • Using the opening tools, pry the LED screen back to give access to the connecting ribbon cable.
  • The LED screen is connected to the mother board with light adhesive which can easily be separated.
단계 2 Disconnect the display  ¶
Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
  • Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
  • The solder iron creates high temperatures that may cause bodily harm.
  • Only make contact with the solder connection. This will ensure no damage to the mother board or any other components of the phone
단계 3 Remove the display  ¶
Once the solder connection has heated up, apply slight tension to the ribbon cable which will allow for complete removal of the LED screen. Once the solder connection has heated up, apply slight tension to the ribbon cable which will allow for complete removal of the LED screen.
  • Once the solder connection has heated up, apply slight tension to the ribbon cable which will allow for complete removal of the LED screen.
