메인 콘텐츠로 스킵하기
도움말
Toshiba Satellite A105-S4011 Touchpad Replacement
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
더 나은 소개글
더 나은 소개글
소개글을 완성 또는 수정하여 해당 안내서를 개선하여 주십시오.
This guide will instruct you on how to remove the current touchpad from this laptop and how to re-install another. This is a straightforward process and it requires little time.
  • 작성자: Daniel Frois
  • 예상 시간 30 분
  • 난이도: 보통
섹션
단계 1 Touchpad  ¶
This step requires removal of the screws under the laptop. Locate the screws that are embedded within a hole on the underside of the laptop. These are the screws that require removal. Screws that support a plate are not required to be removed. All necessary crews to be removed are highlighted with red circles (in the final picture).
단계 1 Touchpad  ¶
  • This step requires removal of the screws under the laptop. Locate the screws that are embedded within a hole on the underside of the laptop. These are the screws that require removal.
  • Screws that support a plate are not required to be removed.
  • All necessary crews to be removed are highlighted with red circles (in the final picture).
단계 2  ¶
Now that the screws on the underside of the laptop have been removed, the plastic body can be separated as shown. The body should be removed slowly and might be a little snug initially before coming apart. Work your way around the case, opening it up little by little.
단계 2  ¶
  • Now that the screws on the underside of the laptop have been removed, the plastic body can be separated as shown.
  • The body should be removed slowly and might be a little snug initially before coming apart. Work your way around the case, opening it up little by little.
단계 3  ¶
The touch-pad is located as shown in the first picture provided. Locate and disconnect the electronic strip (cable) that is connected on the touch-pad unit. Locate and disconnect the electronic strip (cable) that is connected on the touch-pad unit.
단계 3  ¶
  • The touch-pad is located as shown in the first picture provided.
  • Locate and disconnect the electronic strip (cable) that is connected on the touch-pad unit.
단계 4  ¶
Locate the five (5) screws that support the touch-pad and remove them. The screws may be covered by tape. If the tape is present, peel it so that the screws are exposed for removal. Once the screws are removed and the tape is peeled back , the touch-pad should be able to be removed without any issues.
단계 4  ¶
  • Locate the five (5) screws that support the touch-pad and remove them.
  • The screws may be covered by tape. If the tape is present, peel it so that the screws are exposed for removal.
  • Once the screws are removed and the tape is peeled back , the touch-pad should be able to be removed without any issues.
  • Finally, a new touch-pad can be installed. To re-assemble the laptop, follow the reverse order of the disassembly.
