메인 콘텐츠로 스킵하기
도움말
기술: How to Repair an Apple AC Adapter Broken Cable
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
A way to repair your Apple AC Adapter with minimal effort whilst also leaving the least amount of marks.
  • 작성자: Darie H
  • 예상 시간 1 - 2 시간
  • 난이도: 어려움
The Apple AC adapter cable often starts to fray/separate near where the cable meets the power brick. This guide shows how to repair it cleanly while maintaining the original look of your AC adapter.
Alternatively, you can follow this guide to replace the cord instead of repairing it.
단계 1 How to Repair an Apple AC Adapter Broken Cable  ¶
The first thing you'll need, is to have managed to break the cable of your MagSafe Adapter.
  • The first thing you'll need, is to have managed to break the cable of your MagSafe Adapter.
단계 2  ¶
Lift up the 2 flaps, and SLOWLY separate the two halves of the casing with a set of pliers. Be careful, as this step can potentially do the most damage to the outer casing. Take your time, and wrap the plier tips with some tape if you don't want to leave any marks.
단계 2  ¶
  • Lift up the 2 flaps, and SLOWLY separate the two halves of the casing with a set of pliers.
  • Be careful, as this step can potentially do the most damage to the outer casing. Take your time, and wrap the plier tips with some tape if you don't want to leave any marks.
  • After a good couple of pops, you'll be able to hold it open with your hands.
단계 3  ¶
Rinse and repeat: now heat the lower part of the adapter. Gently pull the two halves of the case apart.
단계 3  ¶
  • Rinse and repeat: now heat the lower part of the adapter.
  • Gently pull the two halves of the case apart.
단계 4  ¶
Heat the lower part some more—this will loosen the AC Input Connector, which should still be stuck to one of the two sides. Give it a bit of screwdriver action if it's stubborn like mine was.
단계 4  ¶
  • Heat the lower part some more—this will loosen the AC Input Connector, which should still be stuck to one of the two sides.
  • Give it a bit of screwdriver action if it's stubborn like mine was.
단계 5  ¶
If all went well, you should have completely separated the 2 parts of the case from the actual power supply.
단계 5  ¶
  • If all went well, you should have completely separated the 2 parts of the case from the actual power supply.
단계 6  ¶
Cut both wires as close to the little plastic thingy as possible.
단계 6  ¶
  • Cut both wires as close to the little plastic thingy as possible.
단계 7  ¶
To reuse the plastic stopper, using whatever you want (I used a cutting plier), remove as much of the white plastic as to still leave the lip for further reattachment. Using your normal pliers and/or a fine screwdriver/knife, try to jam out a little metal part that is clipping the two wires and attaching them to the white plastic.
단계 7  ¶
  • To reuse the plastic stopper, using whatever you want (I used a cutting plier), remove as much of the white plastic as to still leave the lip for further reattachment.
  • Using your normal pliers and/or a fine screwdriver/knife, try to jam out a little metal part that is clipping the two wires and attaching them to the white plastic.
  • Next, pull out all the wires.
단계 8  ¶
The plastic mantle of the wire will still likely be attached to the plastic stopper. To get it out, sprinkle the thing with some rubbing alcohol (or water). Then, push it out with a bigger screwdriver head.
단계 8  ¶
  • The plastic mantle of the wire will still likely be attached to the plastic stopper.
  • To get it out, sprinkle the thing with some rubbing alcohol (or water).
  • Then, push it out with a bigger screwdriver head.
  • This took the most time in my case, so, be patient—it'll give up eventually.
단계 9  ¶
Now to start prepping the wires:
단계 9  ¶
  • Now to start prepping the wires:
  • Cut the main wire at a few centimetres away from where the tear occurred. This'll ensure you won't be reusing any damaged piece of the wire.
단계 10  ¶
Using a utility knife or wire cutters, expose and prep the 4 wires like so. Using a utility knife or wire cutters, expose and prep the 4 wires like so.
단계 10  ¶
  • Using a utility knife or wire cutters, expose and prep the 4 wires like so.
단계 11  ¶
Using a soldering iron/gun, apply solder to all 4 ends of the wires. Using a soldering iron/gun, apply solder to all 4 ends of the wires. Using a soldering iron/gun, apply solder to all 4 ends of the wires.
단계 11  ¶
  • Using a soldering iron/gun, apply solder to all 4 ends of the wires.
단계 12  ¶
Thread the rubber/plastic stopper back onto the wires.
단계 12  ¶
  • Thread the rubber/plastic stopper back onto the wires.
  • Do this AFTER you have applied solder to the tips of the wires.
  • To do this, I sprayed a bit of alcohol on the whole thing, and pulled the wires with the pliers. It required a pretty decent amount of force—but don't worry, the cables should hold without a problem. Just make sure you're pulling both at the same time.
  • Note that I've also added a tiny length of shrink-tube on the exposed wire.
단계 13  ¶
Add 2 lengths of shrink-tube on the 2 wires. Now, solder the 4 wires together. Make sure to connect white to white, and black to the bare metal one.
단계 13  ¶
  • Add 2 lengths of shrink-tube on the 2 wires.
  • Now, solder the 4 wires together.
  • Make sure to connect white to white, and black to the bare metal one.
  • Make sure to do this step really quickly, as the heat-shrink tube will contract from the heat of the soldering.
  • Alternatively, you could just use duct tape—just be careful so it doesn't slide off when you're bending the wires.
  • Move the shirk-tube over the soldering spots, and heat it up. (Mine fell a bit short, so I did end up using a bit of duct tape.)
단계 14  ¶
Set the plastic stopper in its groove. Put the 4 pieces of the wire holder assembly back into place. Make sure the metal part goes UNDER the case, like so.
단계 14  ¶
  • Set the plastic stopper in its groove.
  • Put the 4 pieces of the wire holder assembly back into place.
  • Make sure the metal part goes UNDER the case, like so.
단계 15  ¶
Close up the case! You're done. I had some issues getting it to clamp back properly—check the part of the case with the groove on the edge for any left over pieces of plastic, and try your best to get them out.
단계 15  ¶
  • Close up the case! You're done.
  • I had some issues getting it to clamp back properly—check the part of the case with the groove on the edge for any left over pieces of plastic, and try your best to get them out.
  • You can glue the case back together, or, in my case, since I had none, I used clear duct tape to stick it back together.
  • Make sure you take good care of the wire from now on; make sure it doesn't get bent when you carry it around. :)
