메인 콘텐츠로 스킵하기
도움말
Toshiba Satellite A105-S4284 Speakers Replacement
This guide outlines the steps for removing the speakers to clean or replace.
  • 작성자: Josh
  • 예상 시간 30 분
  • 난이도: 어려움
Speakers tend to degrade with time, which can result in a loss of audio quality. Speakers can also accumulate layers of dust and debris that lessens their quality. Occasionally a speaker will altogether stop working. in each of these cases it can be helpful to remove the offending speaker. The speakers in this laptop are hard to get to but, with the proper tools and instructions can be removed.
섹션
단계 1 Speakers  ¶
Remove the lower half of the laptop and lay upper half on its top.
단계 1 Speakers  ¶
  • Remove the lower half of the laptop and lay upper half on its top.
단계 2  ¶
Using the Phillips screwdriver remove the two 4.0mm screws holding each of the speakers housings to the case. Remove the speakers from the case being careful of the wires.
단계 2  ¶
  • Using the Phillips screwdriver remove the two 4.0mm screws holding each of the speakers housings to the case.
  • Remove the speakers from the case being careful of the wires.
단계 3  ¶
The wires for the speakers are color coded.The red and black  wires are for the right speaker, and the black and white wires are for the left speaker.
단계 3  ¶
  • The wires for the speakers are color coded.The red and black wires are for the right speaker, and the black and white wires are for the left speaker.
