도움말
Toshiba A1304T Camera Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
  • 작성자: Christopher
  • 예상 시간 20 - 30 분
  • 난이도: 보통
Use this guide to replace the Toshiba A1304T camera.
단계 1 Camera  ¶
Using a small Phillips screwdriver, remove the two black screws from the positions indicated. Gently pull the silver plate from the phone using your fingers.
단계 1 Camera  ¶
  • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
  • Gently pull the silver plate from the phone using your fingers.
단계 2  ¶
Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically. Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger. Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
단계 2  ¶
  • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
  • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
