도움말
HTC EVO 4G Power Button Replacement
How to access the power button in order to replace it.
  • 작성자: Sage Jurado
  • 예상 시간 30 - 40 분
  • 난이도: 보통
This guide will walk you through the steps necessary to access the power button on your HTC Evo 4G for replacement. The four steps require no special skills. There are small parts that could get lost easily upon removal if not handled carefully.
단계 1 Power Button  ¶
Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
단계 1 Power Button  ¶
  • Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
단계 2  ¶
Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone. Lift off the inner frame from the rest of the phone to remove it. Lift off the inner frame from the rest of the phone to remove it.
단계 2  ¶
  • Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone.
  • Lift off the inner frame from the rest of the phone to remove it.
단계 3  ¶
Carefully remove the power button located at the top of the phone Carefully remove the power button located at the top of the phone
단계 3  ¶
  • Carefully remove the power button located at the top of the phone
