도움말
Nintendo 3DS XL Power Button Replacement
After following this guide you will be able to reach the Power Button on your Nintendo 3DS XL and hopefully be able to turn the device back on to play all your favorite games once again.
This guide to replace the Power Button will take you through the steps of disassembling the Nintendo 3DS past the motherboard in order to access the Power Button.
섹션
단계 1 Power Button  ¶
Using tweezers remove the rubber cap located on the bottom left hand corner. Use the tweezers to pull out the power button. Use the tweezers to pull out the power button.
단계 1 Power Button  ¶
  • Using tweezers remove the rubber cap located on the bottom left hand corner.
  • Use the tweezers to pull out the power button.
