메인 콘텐츠로 스킵하기
도움말
Nintendo 3DS XL IR Board Replacement
This guide will aid in the replacement of the IR Board, or the infrared sensor that is used in certain games for the Nintendo 3DS XL.
The guide will help take apart the Nintendo 3DS XL to uncover the motherboard, then identify the IR Board in order to be replaced.
단계 1 IR Board  ¶
Position the device such that the game cartridge slot is located at the top. Locate the IR board located on the upper right side of the motherboard.
단계 1 IR Board  ¶
  • Position the device such that the game cartridge slot is located at the top.
  • Locate the IR board located on the upper right side of the motherboard.
  • The IR board is installed upside-down in these photos by mistake. Installing it this way will result in your DS failing to start. Note the orientation of your IR board before you remove it, and reinstall it the same way.
  • Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
