도움말
Sony NEX-5R Lens Mount Replacement
This guide will lead you through the steps on how to replace the lens mount of your Sony NEX-5R.
  • 작성자: Emily Trujillo
  • 예상 시간 5 - 10 분
  • 난이도: 쉬움
Replacing the lens mount requires removing any lens that is already attached then simply removing the casing of the lens mount.
단계 1 Lens Mount  ¶
Hold lens and camera securely with two hands. With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
단계 1 Lens Mount  ¶
  • Hold lens and camera securely with two hands.
  • With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
단계 2  ¶
Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
단계 2  ¶
  • Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
  • Make sure to keep track of these screws and not misplace them.
단계 3  ¶
Remove the silver plate by gently pinching with your fingers.
단계 3  ¶
  • Remove the silver plate by gently pinching with your fingers.
단계 4  ¶
Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
단계 4  ¶
  • Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
단계 5  ¶
Using the tweezers, grab the thin silver ring and lift up.
단계 5  ¶
  • Using the tweezers, grab the thin silver ring and lift up.
단계 6  ¶
The camera mount should now be barren and look like this.
단계 6  ¶
  • The camera mount should now be barren and look like this.
