메인 콘텐츠로 스킵하기
도움말
Asus Transformer T100 Battery Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
Replace the battery in your Asus Transformer T100.
  • 작성자: Taylor Pantiga
  • 예상 시간 10 - 20 분
  • 난이도: 보통
The battery is located inside the tablet part of the device. The plastic backing must be removed before the battery can be accessed.
단계 1 Battery  ¶
Remove the copper tape carefully.
단계 1 Battery  ¶
  • Remove the copper tape carefully.
단계 2  ¶
Gently pull back the yellow transparent plastic covering on top of the battery connection port. Gently pull back the yellow transparent plastic covering on top of the battery connection port.
단계 2  ¶
  • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
단계 3  ¶
Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out. The battery wire harness will slide out as the battery is pried up. The battery wire harness will slide out as the battery is pried up.
단계 3  ¶
  • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
  • The battery wire harness will slide out as the battery is pried up.
단계 4  ¶
Remove the battery by slowly peeling the battery away from the connected side. The adhesive on the back will pull away from the battery.
단계 4  ¶
  • Remove the battery by slowly peeling the battery away from the connected side.
  • The adhesive on the back will pull away from the battery.
