메인 콘텐츠로 스킵하기
도움말
Disassembling LG VX8550 Front Case
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
한 단계 누락
한 단계 누락
이런! 해당 안내서는 현재 몇몇 중요한 단계가 빠져 있습니다.
  • 작성자: Nathan Jones
  • 예상 시간 5 분
  • 난이도: 보통
Steps to remove the LG VX8550 front case
섹션
단계 1 Front Case  ¶
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
단계 1 Front Case  ¶
  • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
단계 2  ¶
Remove the 6 screws with a Phillips #00 Screwdriver.
단계 2  ¶
  • Remove the 6 screws with a Phillips #00 Screwdriver.
단계 3  ¶
Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
단계 3  ¶
  • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
단계 4  ¶
Carefully lift the slider mechanism to see the ribbon cables underneath.
단계 4  ¶
  • Carefully lift the slider mechanism to see the ribbon cables underneath.
단계 5  ¶
Slide ribbon cable through the slider mechanism.
단계 5  ¶
  • Slide ribbon cable through the slider mechanism.
단계 6  ¶
Separate the two halves.
단계 6  ¶
  • Separate the two halves.
