도움말
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Inverter/Antenna Cables Replacement
Use this guide to replace a worn-out set of inverter/antenna cables.
단계 1 Inverter/Antenna Cables  ¶
Remove the three pieces of tape securing the camera cable to the display assembly.
  • Remove the three pieces of tape securing the camera cable to the display assembly.
단계 2  ¶
Use the tip of a spudger or your fingernail to flip up the ZIF retaining flap on the camera cable socket at the edge of the camera board near the top center of the front display bezel. Be sure you are prying up on the retaining flap, not the socket itself.
단계 2  ¶
  • Use the tip of a spudger or your fingernail to flip up the ZIF retaining flap on the camera cable socket at the edge of the camera board near the top center of the front display bezel.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • Pull the camera cable out of its socket.
단계 3  ¶
Peel the camera cable off the foam tape along the top edge of the display.
단계 3  ¶
  • Peel the camera cable off the foam tape along the top edge of the display.
단계 4  ¶
Remove the inverter/antenna cables from the display.
단계 4  ¶
  • Remove the inverter/antenna cables from the display.
