메인 콘텐츠로 스킵하기
도움말
iMac Intel 21.5" EMC 2805 Logic Board Assembly Replacement
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
Prereq for removing logic board.
단계 1 Logic Board Assembly  ¶
Use the tip of a spudger to walk the left speaker cable connector out of its socket. It is recommended to first press on one side of the connector, then press on the other side until freed.
  • Use the tip of a spudger to walk the left speaker cable connector out of its socket.
  • It is recommended to first press on one side of the connector, then press on the other side until freed.
단계 2  ¶
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
단계 2  ¶
  • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
단계 3  ¶
In a similar fashion as the previous step, de-route the combo SATA data/power cable up out of the retaining clip. In a similar fashion as the previous step, de-route the combo SATA data/power cable up out of the retaining clip.
단계 3  ¶
  • In a similar fashion as the previous step, de-route the combo SATA data/power cable up out of the retaining clip.
단계 4  ¶
Use a pair of tweezers to flip up the metal retaining bracket on the iSight camera cable connector. Pull the iSight camera cable straight out of its socket on the logic board. This is a delicate connector that can be easily damaged.
단계 4  ¶
  • Use a pair of tweezers to flip up the metal retaining bracket on the iSight camera cable connector.
  • Pull the iSight camera cable straight out of its socket on the logic board.
  • This is a delicate connector that can be easily damaged.
단계 5  ¶
If necessary, use the tip of a spudger to peel back the tabs covering the antenna connectors. If necessary, use the tip of a spudger to peel back the tabs covering the antenna connectors. If necessary, use the tip of a spudger to peel back the tabs covering the antenna connectors.
단계 5  ¶
  • If necessary, use the tip of a spudger to peel back the tabs covering the antenna connectors.
단계 6  ¶
Use the tip of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card. Note the original positions for each connector when reconnecting the cables. Note the original positions for each connector when reconnecting the cables.
단계 6  ¶
  • Use the tip of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
  • Note the original positions for each connector when reconnecting the cables.
단계 7  ¶
Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board. Push the cable slightly to the right. Push the cable slightly to the right.
단계 7  ¶
  • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
  • Push the cable slightly to the right.
단계 8  ¶
Remove the following screws securing the exhaust duct to the rear enclosure:
단계 8  ¶
  • Remove the following screws securing the exhaust duct to the rear enclosure:
  • Two 6.3 mm T8 screws
  • Two 4.7 mm T8 screws
단계 9  ¶
Remove the four 7.2 mm T10 screws securing the logic board to the rear enclosure.
단계 9  ¶
  • Remove the four 7.2 mm T10 screws securing the logic board to the rear enclosure.
단계 10  ¶
Use a pair of tweezers to peel the tape covering the exhaust duct.
단계 10  ¶
  • Use a pair of tweezers to peel the tape covering the exhaust duct.
단계 11  ¶
Tilt the top of the logic board away from the rear enclosure. Tilt the top of the logic board away from the rear enclosure.
단계 11  ¶
  • Tilt the top of the logic board away from the rear enclosure.
단계 12  ¶
Lift the logic board straight up and out of the iMac. Be careful not to snag the board on any of the rear case's screw posts.
단계 12  ¶
  • Lift the logic board straight up and out of the iMac.
  • Be careful not to snag the board on any of the rear case's screw posts.
  • The I/O inputs at the bottom of the logic board will be the greatest challenge. It is recommended to pull gently to avoid any damage.
단계 13  ¶
When reinstalling the logic board, check the alignment of the exterior I/O ports. The logic board can sit crooked even when secured with all its screws. Use a USB flash drive and/or ethernet cable to keep the logic board aligned while you screw it in.
단계 13  ¶
  • When reinstalling the logic board, check the alignment of the exterior I/O ports. The logic board can sit crooked even when secured with all its screws.
  • Use a USB flash drive and/or ethernet cable to keep the logic board aligned while you screw it in.
