도움말
iMac Intel 21.5" EMC 2805 Heat Sink Replacement
잠재적으로 위험한
잠재적으로 위험한
절차를 제대로 따르지 않을 경우 부상을 입을 수 있습니다. 주의를 요하며 모든 경고를 따라주십시오.
Replace the Heat Sink in your iMac Intel 21.5" EMC 2805.
Use this guide to replace the heat sink.
Don't forget to follow our thermal paste application guide after you have removed your heat sink.
단계 1 Heat Sink  ¶
The following screws secure the heat sink to the logic board:
단계 1 Heat Sink  ¶
  • The following screws secure the heat sink to the logic board:
  • Remove the two T8 screws from the exhaust port end of the heat sink.
  • Loosen, but do not remove, the four captive T8 screws securing the CPU end of the heat sink.
단계 2  ¶
Slowly lift and remove the heat sink from the logic board. When reassembling your iMac, follow our thermal paste application guide to reapply the thermal paste.
단계 2  ¶
  • Slowly lift and remove the heat sink from the logic board.
  • When reassembling your iMac, follow our thermal paste application guide to reapply the thermal paste.
