메인 콘텐츠로 스킵하기
도움말
iPad 2 Wi-Fi EMC 2560 Volume and Power Button Cable Replacement
Replace the volume and power buttons and Smart Cover sensor in an iPad 2 Wi-Fi EMC 2560.
  • 작성자: Sam Goldheart
  • 예상 시간 1 - 3 시간
  • 난이도: 매우 어려움
Use this guide to replace the volume and power button cable assembly in your iPad 2 Wi-Fi EMC 2560. This assembly also includes the sensor responsible for detecting the magnet in a Smart Cover.
단계 1 Volume and Power Button Cable  ¶
Remove the single 2.0 mm Phillips #000 screw securing the camera bracket.
  • Remove the single 2.0 mm Phillips #000 screw securing the camera bracket.
단계 2  ¶
Remove the plastic camera bracket.
단계 2  ¶
  • Remove the plastic camera bracket.
단계 3  ¶
Use the point of a spudger to flip the retaining tab on the button cable ZIF connector. Pull the button cable straight out of its socket on the upper component board. Pull the button cable straight out of its socket on the upper component board.
단계 3  ¶
  • Use the point of a spudger to flip the retaining tab on the button cable ZIF connector.
  • Pull the button cable straight out of its socket on the upper component board.
단계 4  ¶
Remove the following screws from the volume/power button assembly cable:
단계 4  ¶
  • Remove the following screws from the volume/power button assembly cable:
  • Two 3.0 mm Phillips #000 screws at a 45º angle, securing the power button bracket
  • Two 5.0 mm Phillips #000 screws
  • One 2.0 mm Phillips #000 screw at a 45º angle
단계 5  ¶
Remove the metal bracket securing the rotation lock/silent switch.
단계 5  ¶
  • Remove the metal bracket securing the rotation lock/silent switch.
단계 6  ¶
Pull the power button cable out of the recess in the rear case and bend it out of the way. The ribbon cable contains the mechanical button that needs to mate with the plastic button cover that remains in the case. The ribbon cable contains the mechanical button that needs to mate with the plastic button cover that remains in the case.
단계 6  ¶
  • Pull the power button cable out of the recess in the rear case and bend it out of the way.
  • The ribbon cable contains the mechanical button that needs to mate with the plastic button cover that remains in the case.
단계 7  ¶
Use the point of an opening pick to gently peel the Smart Cover sleep/wake sensor up off the rear case. Use the point of an opening pick to gently peel the Smart Cover sleep/wake sensor up off the rear case. Use the point of an opening pick to gently peel the Smart Cover sleep/wake sensor up off the rear case.
단계 7  ¶
  • Use the point of an opening pick to gently peel the Smart Cover sleep/wake sensor up off the rear case.
단계 8  ¶
Use the center screw hole of the volume control bracket to tilt it out toward the edge of the case and then pull it up out of its recess. Do not remove the bracket entirely as it is still attached to the button ribbon cable. Do not remove the bracket entirely as it is still attached to the button ribbon cable.
단계 8  ¶
  • Use the center screw hole of the volume control bracket to tilt it out toward the edge of the case and then pull it up out of its recess.
  • Do not remove the bracket entirely as it is still attached to the button ribbon cable.
단계 9  ¶
Carefully peel the connector end of the button cable up off of the rear case. Stop peeling before the cable branches off to the volume buttons.
단계 9  ¶
  • Carefully peel the connector end of the button cable up off of the rear case.
  • Stop peeling before the cable branches off to the volume buttons.
단계 10  ¶
Remove the button cable assembly from the rear case.
단계 10  ¶
  • Remove the button cable assembly from the rear case.
단계 11  ¶
If your replacement part comes with the metal button brackets attached, you can skip the following steps. Peel the power button off of the power button bracket.
단계 11  ¶
  • If your replacement part comes with the metal button brackets attached, you can skip the following steps.
  • Peel the power button off of the power button bracket.
  • Note the orientation and adhesive placement for reassembly.
단계 12  ¶
Insert the point of an opening pick between the rotation lock/silent switch and its bracket to sever the adhesive there. Insert the point of an opening pick between the rotation lock/silent switch and its bracket to sever the adhesive there. Insert the point of an opening pick between the rotation lock/silent switch and its bracket to sever the adhesive there.
단계 12  ¶
  • Insert the point of an opening pick between the rotation lock/silent switch and its bracket to sever the adhesive there.
단계 13  ¶
Slide the opening pick under the remaining portion of the rotation lock/silent switch to peel it up off the button bracket. Slide the opening pick under the remaining portion of the rotation lock/silent switch to peel it up off the button bracket. Slide the opening pick under the remaining portion of the rotation lock/silent switch to peel it up off the button bracket.
단계 13  ¶
  • Slide the opening pick under the remaining portion of the rotation lock/silent switch to peel it up off the button bracket.
단계 14  ¶
Use the point of the opening pick to peel the mechanical volume buttons up from the bracket. Remove the button cable assembly from the button bracket. Remove the button cable assembly from the button bracket.
단계 14  ¶
  • Use the point of the opening pick to peel the mechanical volume buttons up from the bracket.
  • Remove the button cable assembly from the button bracket.
단계 15  ¶
The following steps show how to remove the button covers from the rear case of the iPad. If you are simply replacing the button cable, you can leave the button covers in place. Remove the sleep/power button form the rear case.
단계 15  ¶
  • The following steps show how to remove the button covers from the rear case of the iPad. If you are simply replacing the button cable, you can leave the button covers in place.
  • Remove the sleep/power button form the rear case.
  • Note the orientation for reassembly, the metal spring bar should fall down toward the rear of the case.
단계 16  ¶
Remove the rotation lock/silent switch from the rear case. Note the orientation for reassembly. The mechanical switch will also need to mate with this button cover; ensure that they properly interlock.
단계 16  ¶
  • Remove the rotation lock/silent switch from the rear case.
  • Note the orientation for reassembly. The mechanical switch will also need to mate with this button cover; ensure that they properly interlock.
단계 17  ¶
Use the tip of a spudger to push the volume rocker into the interior of the rear case. Remove the volume rocker from the rear case. Remove the volume rocker from the rear case.
단계 17  ¶
  • Use the tip of a spudger to push the volume rocker into the interior of the rear case.
  • Remove the volume rocker from the rear case.
