메인 콘텐츠로 스킵하기
도움말
LG LX150 Internal Back Cover Replacement
This guide will show you how to remove the plastic cover between the battery and motherboard.
단계 1 Internal Back Cover  ¶
Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver. Insert the flat end of the spudger in-between the black and  blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners. Insert the flat end of the spudger in-between the black and  blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
  • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
단계 2  ¶
Remove the internal back cover after loosening all the corners. The second picture below is what you will see after removing the internal back cover.
단계 2  ¶
  • Remove the internal back cover after loosening all the corners.
  • The second picture below is what you will see after removing the internal back cover.
