메인 콘텐츠로 스킵하기
도움말
Olympus D590 LCD screen Replacement
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
잘못된 도구
잘못된 도구
이미지 및/또는 텍스트의 올바른 도구를 사용하여 해당 안내서를 더 효과적으로 만들어 주십시오.
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
  • 작성자: Sara
  • 예상 시간 30 분
  • 난이도: 어려움
This guide will give step-by-step instructions on how to install a LCD screen in a Olympus D590 camera.
섹션
단계 1 LCD screen  ¶
Unscrew the screw shown in the picture from LCD screen.
단계 1 LCD screen  ¶
  • Unscrew the screw shown in the picture from LCD screen.
단계 2  ¶
Remove the side pannel by sliding it off the body of the camera. Lift the camera no more than 3cm to make sure all screws have been taken off.
단계 2  ¶
  • Remove the side pannel by sliding it off the body of the camera.
  • Lift the camera no more than 3cm to make sure all screws have been taken off.
단계 3  ¶
Flip camera so you are looking at the front. Remove gray and blue wiring with tweasers by gently wiggling and pulling.
단계 3  ¶
  • Flip camera so you are looking at the front.
  • Remove gray and blue wiring with tweasers by gently wiggling and pulling.
  • Be careful not to rip the wiring tape with the tweezers.
단계 4  ¶
Locate the tape securing the wiring with the gray end piece located on top of the camera. Gently lift up on the tape till all wires are exposed.
단계 4  ¶
  • Locate the tape securing the wiring with the gray end piece located on top of the camera.
  • Gently lift up on the tape till all wires are exposed.
단계 5  ¶
Flip Camera to the bottom side as shown.
단계 5  ¶
  • Flip Camera to the bottom side as shown.
  • Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
단계 6  ¶
Flip camera so the front is facing you. Locate speaker in upper right hand corner. Gently lift with tweasers.
단계 6  ¶
  • Flip camera so the front is facing you.
  • Locate speaker in upper right hand corner.
  • Gently lift with tweasers.
  • Feed wiring through designated spot so that it is no longer connected to the camera.
단계 7  ¶
Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera. Gently pull the thick yellow wiring out by using the forefinger and thumb.
단계 7  ¶
  • Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
  • Gently pull the thick yellow wiring out by using the forefinger and thumb.
