메인 콘텐츠로 스킵하기
도움말
Olympus Stylus 410 Speaker Replacement
전제 조건 누락
전제 조건 누락
해당 안내서는 작업 시작 방법에 대한 정보가 없습니다. 전제 조건 안내서를 만들어 주십시오!
  • 작성자: Gabriela Igel
  • 예상 시간 15 - 20 분
  • 난이도: 보통
Use this guide to replace the Olympus Stylus 410 speaker.
단계 1 Speaker  ¶
Use a spudger to remove the speaker. It is attached by a double sided adhesive so it should just peel off. Use a spudger to remove the speaker. It is attached by a double sided adhesive so it should just peel off. Use a spudger to remove the speaker. It is attached by a double sided adhesive so it should just peel off.
단계 1 Speaker  ¶
  • Use a spudger to remove the speaker. It is attached by a double sided adhesive so it should just peel off.
단계 2  ¶
Un-solder the wires to remove the speaker.
단계 2  ¶
  • Un-solder the wires to remove the speaker.
