메인 콘텐츠로 스킵하기
도움말
Nokia 3300B Keyboard Replacement.
Replace the keyboard of the Nokia 3300B.
  • 작성자: Chris Colwell
  • 예상 시간 15 - 20 분
  • 난이도: 쉬움
Use this guide to replace the keyboard of the Nokia 3300B.
섹션
단계 1 Keyboard  ¶
Gently push the blue tabs on the top of the phone out of their slots. With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
단계 1 Keyboard  ¶
  • Gently push the blue tabs on the top of the phone out of their slots.
  • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
  • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
단계 2  ¶
With the screen still facing you, lift and remove the blue faceplate.
단계 2  ¶
  • With the screen still facing you, lift and remove the blue faceplate.
단계 3  ¶
Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
단계 3  ¶
  • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
  • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
  • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
