도움말
MacBook Unibody Model A1342 Display Data/Camera Cable Replacement
Replace a worn-through display data cable.
Use this guide to replace a display data/camera cable that may be worn through from repeatedly opening and closing the display.
섹션
단계 1 Display Data/Camera Cable  ¶
Remove the two small pieces of black tape securing the display data/camera cable to the rear display bezel.
  • Remove the two small pieces of black tape securing the display data/camera cable to the rear display bezel.
단계 2  ¶
Use the pointed tip of a spudger to pry the camera board off the display assembly. Disconnect the camera cable by pulling its connector away from the socket on the camera board.
단계 2  ¶
  • Use the pointed tip of a spudger to pry the camera board off the display assembly.
  • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
단계 3  ¶
De-route the display data/camera cable from the slot cut into the rear display bezel.
단계 3  ¶
  • De-route the display data/camera cable from the slot cut into the rear display bezel.
단계 4  ¶
Carefully pull the display data/camera cable out from under the frame attached to the rear display bezel and remove it from the display assembly.
단계 4  ¶
  • Carefully pull the display data/camera cable out from under the frame attached to the rear display bezel and remove it from the display assembly.
