도움말
MacBook Pro 15" Unibody Mid 2010 Battery Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
Replace the battery on your MacBook Pro 15" Unibody Mid 2010.
  • 작성자: Walter Galan
  • 예상 시간 10 - 45 분
  • 난이도: 쉬움
Use this guide to replace an aging battery. If your battery is swollen, take appropriate precautions.
단계 1 Battery  ¶
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
단계 1 Battery  ¶
  • Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
  • Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
  • You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
단계 2  ¶
Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
단계 2  ¶
  • Use the tip of your finger to carefully peel back the corner of the warning label to reveal a hidden Tri-point screw.
  • Remove the last 7.4 mm Tri-point screw securing the battery to the upper case.
단계 3  ¶
Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case. Do not try to completely remove the battery just yet.
단계 3  ¶
  • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
  • Do not try to completely remove the battery just yet.
단계 4  ¶
Tilt the battery away from the logic board enough to access the battery cable connector.
단계 4  ¶
  • Tilt the battery away from the logic board enough to access the battery cable connector.
  • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
  • Pull the battery cable connector away from the center of the logic board.
  • If you're installing a new battery, you should calibrate it after installation:
  • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
