메인 콘텐츠로 스킵하기
도움말
HTC Evo 4G Rear Inner Frame Replacement
Rear inner frame replacement.
Remove the rear inner frame to gain access to the internals of the HTC Evo 4G.
섹션
단계 1 Rear Inner Frame  ¶
Remove six T5 Torx screws securing the rear inner frame to the inner case.
  • Remove six T5 Torx screws securing the rear inner frame to the inner case.
단계 2  ¶
Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
단계 2  ¶
  • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
  • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
단계 3  ¶
Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo. Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
단계 3  ¶
  • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
단계 4  ¶
Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo. Pry up the rear inner frame along the right edge using the method described in previous steps. Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
단계 4  ¶
  • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
  • Pry up the rear inner frame along the right edge using the method described in previous steps.
  • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
단계 5  ¶
Remove the rear inner frame from the rest of the Evo.
단계 5  ¶
  • Remove the rear inner frame from the rest of the Evo.
