메인 콘텐츠로 스킵하기
도움말
Motorola V188 Battery Replacement
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
This guide will demonstrate how to replace the battery in a Motorola V188
  • 작성자: rab777hp
  • 예상 시간 1 분
  • 난이도: 아주 쉬움
This guide goes through the steps of accessing and removing the battery for a Motorola V188
관련 부품
단계 1 Battery  ¶
Depress the button at the bottom of the rear panel and slide the panel down to remove Remove the rear panel Remove the rear panel
단계 1 Battery  ¶
  • Depress the button at the bottom of the rear panel and slide the panel down to remove
  • Remove the rear panel
단계 2  ¶
Insert your thumb in the gap between the button and battery and push upwards Then pull upwards to pull the battery out of the phone
단계 2  ¶
  • Insert your thumb in the gap between the button and battery and push upwards
  • Then pull upwards to pull the battery out of the phone
