도움말
MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement
Replace the logic board in your MacBook Pro 15" Unibody Mid 2010.
Use this guide to replace your bare logic board. This requires removal of every component attached to the logic board.
단계 1 Logic Board  ¶
If necessary, lift the microphone out of its recess in the left speaker housing.
단계 1 Logic Board  ¶
  • If necessary, lift the microphone out of its recess in the left speaker housing.
단계 2  ¶
Remove the two 5 mm Phillips screws securing the left speaker to the logic board.
단계 2  ¶
  • Remove the two 5 mm Phillips screws securing the left speaker to the logic board.
단계 3  ¶
If present, remove the small strip of black tape covering the left speaker connector.
단계 3  ¶
  • If present, remove the small strip of black tape covering the left speaker connector.
  • Carefully pull the left speaker wires upward to lift the left speaker connector out of its socket on the logic board.
단계 4  ¶
Carefully pull the microphone cables upward to lift the microphone connector out of its socket on the logic board.
단계 4  ¶
  • Carefully pull the microphone cables upward to lift the microphone connector out of its socket on the logic board.
단계 5  ¶
Pull the DC-In board cables toward the heat sink to disconnect the DC-In board from its socket on the logic board.
단계 5  ¶
  • Pull the DC-In board cables toward the heat sink to disconnect the DC-In board from its socket on the logic board.
  • Pull the cables parallel to the face of the logic board.
단계 6  ¶
Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
단계 6  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
  • Logic board remains.
  • If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
