메인 콘텐츠로 스킵하기
도움말
MacBook Core Duo Rear Display Bezel Replacement
MacBook Core Duo rear display bezel replacement.
  • 작성자: iRobot
  • 난이도: 어려움
Use this guide to replace the rear panel of your MacBook Core Duo's display assembly.
단계 1 Rear Display Bezel  ¶
Remove the display inverter and its attached cable from the rear display bezel.
  • Remove the display inverter and its attached cable from the rear display bezel.
단계 2  ¶
If it is still stuck to the rear display bezel, pry the sleep magnet out of its housing on the left side of the rear display bezel.
단계 2  ¶
  • If it is still stuck to the rear display bezel, pry the sleep magnet out of its housing on the left side of the rear display bezel.
  • Make sure to replace the sleep magnet with the shorter edge facing up.
단계 3  ¶
Pry the right display latch magnet out of its housing. It may help to lift up on the magnet while prying it out. Remove the right display latch magnet.
단계 3  ¶
  • Pry the right display latch magnet out of its housing. It may help to lift up on the magnet while prying it out.
  • Remove the right display latch magnet.
단계 4  ¶
Pry the left display latch magnet out of its housing. Rear display bezel remains.
단계 4  ¶
  • Pry the left display latch magnet out of its housing.
  • Rear display bezel remains.
