도움말
iPhone 4 Home Button Replacement
Removing the home button and its cover.
  • 작성자: Walter Galan
  • 예상 시간 2 시간
  • 난이도: 어려움
Use this guide to replace a damaged home button to regain use of your iPhone.
단계 1 Home Button  ¶
Use the edge of an iPod opening tool or your fingernail to lift the home button ribbon cable retainer. Be sure you are prying up on the cable retainer, not the socket itself. Be sure you are prying up on the cable retainer, not the socket itself.
단계 1 Home Button  ¶
  • Use the edge of an iPod opening tool or your fingernail to lift the home button ribbon cable retainer.
  • Be sure you are prying up on the cable retainer, not the socket itself.
단계 2  ¶
Use a pair of tweezers to pull the home button ribbon cable out of its socket.
단계 2  ¶
  • Use a pair of tweezers to pull the home button ribbon cable out of its socket.
  • Do not excessively strain the home button ribbon cable, as it is very thin and delicate. Also, be careful with the two small electronic parts on the ribbon cable. It is very easy to damage them with tweezers.
단계 3  ¶
De-route the home button ribbon cable through the inner case and remove the home button from the iPhone.
단계 3  ¶
  • De-route the home button ribbon cable through the inner case and remove the home button from the iPhone.
  • When installing a new part, there may be a protective plastic film on the home button. It can be removed with a spudger or your fingernail.
