메인 콘텐츠로 스킵하기
도움말
Xbox 360 Wireless Controller Triggers Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
Trigger replacement.
Fire away by replacing the triggers on your Xbox 360 Wireless Controller.
섹션
단계 1 Triggers  ¶
Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction. The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot. Push the trigger arm downward.
단계 1 Triggers  ¶
  • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
  • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
  • Push the trigger arm downward.
단계 2  ¶
Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger. Using the previously described technique, pry the housing on the right edge away from the trigger. Rotate the trigger away from the logic board, past its housing.
단계 2  ¶
  • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
  • Using the previously described technique, pry the housing on the right edge away from the trigger.
  • Rotate the trigger away from the logic board, past its housing.
단계 3  ¶
Using a spudger, pry the trigger spring off its peg on the trigger housing. Pull the trigger spring out of the trigger. Pull the trigger spring out of the trigger.
단계 3  ¶
  • Using a spudger, pry the trigger spring off its peg on the trigger housing.
  • Pull the trigger spring out of the trigger.
단계 4  ¶
Slide the trigger toward the right side of the logic board, and rotate it clockwise. Remove the right trigger from the logic board. To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
단계 4  ¶
  • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
  • Remove the right trigger from the logic board.
  • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
