메인 콘텐츠로 스킵하기
도움말
MacBook Pro 17" Unibody Lower Case Replacement
Removing the lower case.
Remove the lower case to access most components in your MacBook Pro 17" Unibody.
단계 1 Lower Case  ¶
Remove the following ten screws securing the lower case to the upper case:
단계 1 Lower Case  ¶
  • Seven 3 mm Phillips screws.
단계 2  ¶
Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case. During reassembly, carefully align the lower case and then press it firmly until both clips engage.
단계 2  ¶
  • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
  • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
  • Remove the lower case.
