메인 콘텐츠로 스킵하기
도움말
MacBook Pro 17" Unibody Logic Board Replacement
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
단계 1 Logic Board  ¶
Use the flat end of a spudger to lift the left fan connector out of its socket on the logic board.
단계 1 Logic Board  ¶
  • Use the flat end of a spudger to lift the left fan connector out of its socket on the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
단계 2  ¶
Remove the three 3.1 mm Phillips screws securing the left fan to the logic board. Remove the left fan from the upper case, minding its cable that may get caught.
단계 2  ¶
  • Remove the three 3.1 mm Phillips screws securing the left fan to the logic board.
  • Remove the left fan from the upper case, minding its cable that may get caught.
단계 3  ¶
Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable. Be sure you are prying up on the retaining flap, not the socket itself.
단계 3  ¶
  • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • Pull the keyboard backlight ribbon cable out of its socket.
단계 4  ¶
Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way.
단계 4  ¶
  • Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way.
  • Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
단계 5  ¶
Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
단계 5  ¶
  • Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
  • The camera cable socket is very fragile. Do not apply any upward force to this socket, as it may break off the logic board. Pull the camera cable parallel to the face of the logic board.
단계 6  ¶
Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
단계 6  ¶
  • Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
단계 7  ¶
Use the flat end of a spudger to lift the subwoofer & right speaker connector out of its socket on the logic board.
단계 7  ¶
  • Use the flat end of a spudger to lift the subwoofer & right speaker connector out of its socket on the logic board.
  • Pry up from beneath the wires.
단계 8  ¶
Use the tip of a spudger or your fingernail to flip up the retaining flap on the IR sensor ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
단계 8  ¶
  • Use the tip of a spudger or your fingernail to flip up the retaining flap on the IR sensor ribbon cable socket.
  • Pull the IR sensor ribbon cable out of its socket.
단계 9  ¶
Remove the following four screws: Two 3.5 mm Phillips screws These may be T5 Torx screws in the Early 2011 model
단계 9  ¶
  • Remove the following four screws:
  • Two 3.5 mm Phillips screws
  • These may be T5 Torx screws in the Early 2011 model
  • Two 1.6 mm Phillips screws
  • Remove both connector shields from the logic board.
단계 10  ¶
Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
단계 10  ¶
  • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
단계 11  ¶
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
단계 11  ¶
  • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable socket.
  • Pull the keyboard ribbon cable out of its socket.
  • For reassembly, it can be helpful to put a small piece of tape on the keyboard ribbon cable (being careful not to stick any to the contacts), to create a small handle. Align the cable with the socket and gently pull with the tape to fully seat it.
단계 12  ¶
Use your fingernail to flip up the retaining flap on the express card cage ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
단계 12  ¶
  • Use your fingernail to flip up the retaining flap on the express card cage ribbon cable socket.
  • Pull the express card cage ribbon cable out of its socket.
단계 13  ¶
Use the flat end of a spudger to lift the hard drive cable connector up and out of its socket on the logic board.
단계 13  ¶
  • Use the flat end of a spudger to lift the hard drive cable connector up and out of its socket on the logic board.
단계 14  ¶
Use the tip of a spudger or your fingernail to flip up the retaining flap on the battery indicator cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
단계 14  ¶
  • Use the tip of a spudger or your fingernail to flip up the retaining flap on the battery indicator cable socket.
  • Pull the battery indicator ribbon cable out of its socket.
단계 15  ¶
Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook. Pull the display data cable out of its socket. The display data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the logic board. Pull the cable parallel to the face of the logic board.
단계 15  ¶
  • Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook.
  • Pull the display data cable out of its socket.
  • The display data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the logic board. Pull the cable parallel to the face of the logic board.
단계 16  ¶
Remove the following eight screws securing the logic board and DC-In board to the upper case:
단계 16  ¶
  • Remove the following eight screws securing the logic board and DC-In board to the upper case:
  • Six 3.2 mm Phillips screws
  • These may be T6 Torx screws on the Early 2011 model.
  • Two 7.6 mm Phillips screws
단계 17  ¶
Handle the logic board assembly by its edges only. Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
단계 17  ¶
  • Handle the logic board assembly by its edges only.
  • Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
  • Note that you'll be removing the logic board and DC-in board together.
  • Carefully pull the ports and DC-In board away from the side of the upper case and remove the logic board assembly, minding any cables that may get caught.
