메인 콘텐츠로 스킵하기
도움말
Nintendo Wii Outer Case Replacement
Remove the Wii's outer case to access internal components.
Use this guide to remove the white plastic outer case protecting the Wii's innards. Removing the outer case requires a Tri-wing screwdriver.
단계 1 Outer Case  ¶
Open the controller port cover until it is perpendicular to the black controller port bezel. Pull the controller port cover straight up to release it from the outer case. Repeat this procedure for the memory card port cover.
단계 1 Outer Case  ¶
  • Open the controller port cover until it is perpendicular to the black controller port bezel.
  • Pull the controller port cover straight up to release it from the outer case.
  • Repeat this procedure for the memory card port cover.
단계 2  ¶
Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel. Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
단계 2  ¶
  • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
  • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
단계 3  ¶
Remove the two 5 mm Phillips screws above the controller ports.
단계 3  ¶
  • Remove the two 5 mm Phillips screws above the controller ports.
단계 4  ¶
Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
단계 4  ¶
  • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
단계 5  ¶
Remove the following screws:
단계 5  ¶
  • Remove the following screws:
  • Two 5 mm Phillips screws
  • One 8.2 mm Tri-Wing screw
단계 6  ¶
Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
단계 6  ¶
  • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
단계 7  ¶
Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
단계 7  ¶
  • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
단계 8  ¶
Lift the outer case straight up off the body of the Wii.
단계 8  ¶
  • Lift the outer case straight up off the body of the Wii.
