도움말
Nintendo Wii Faceplate Replacement
Remove the white plastic panel covering the front face of your Wii.
Use this guide to replace your Wii's faceplate. Replacing the faceplate will provide new blue LEDs that light up around the optical drive opening.
단계 1 Faceplate  ¶
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii. Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
단계 1 Faceplate  ¶
  • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
단계 2  ¶
Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
단계 2  ¶
  • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
단계 3  ¶
Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
단계 3  ¶
  • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
단계 4  ¶
Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
단계 4  ¶
  • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
단계 5  ¶
Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
단계 5  ¶
  • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
단계 6  ¶
Carefully pull the faceplate away from the front of the Wii. Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
단계 6  ¶
  • Carefully pull the faceplate away from the front of the Wii.
  • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
  • Remove the faceplate.
