메인 콘텐츠로 스킵하기
도움말
eMac PRAM Battery Replacement
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
EMC 1903 M8950LL/A 1GHz Uses a 2AA 1.2 Ah High Capacity 3.6V Lithium Battery Replace the battery if your date and time are resetting or your printer or internet setting are being lost.
  • 작성자: mayer
  • 예상 시간 10 분
  • 난이도: 아주 쉬움
How to replace the PRAM Battery
단계 1 PRAM Battery  ¶
Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you. Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
단계 1 PRAM Battery  ¶
  • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
단계 2  ¶
The access panel is held in place by one Phillips screw.  Unscrew it. Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
단계 2  ¶
  • The access panel is held in place by one Phillips screw. Unscrew it.
  • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
단계 3  ¶
The battery is located just to the left and below  the RAM slots.
단계 3  ¶
  • The battery is located just to the left and below the RAM slots.
  • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
  • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument link a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
  • After removal of the old battery and replace with a new one by pressing it into place.
  • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
  • If no internet just set the date and time manually.
  • Next select the Time Zone box. Click the curser on the map to the closest city to you.
  • Next click the Clock box and select the type of display you prefer.
