메인 콘텐츠로 스킵하기
도움말
Sony Cyber-shot DSC-W290 LCD Assembly Replacement
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
This guide is shows you how to replace the Sony Cyber-shot DSC-W290's LCD screen.
  • 작성자: Evan Mayer
  • 예상 시간 20 분
  • 난이도: 보통
This guide will teach you how to replace the Sony Cyber-shot DSC-W290's LCD screen.
단계 1 LCD Assembly  ¶
Gently pull the LCD and its casing away from the motherboard as shown.
단계 1 LCD Assembly  ¶
  • Gently pull the LCD and its casing away from the motherboard as shown.
  • Be careful not to rip out any ribbon cables.
단계 2  ¶
Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard. Do not use excessive force to remove the wire because this may cause it to tear.
단계 2  ¶
  • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
  • Do not use excessive force to remove the wire because this may cause it to tear.
단계 3  ¶
Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard. Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
단계 3  ¶
  • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
단계 4  ¶
Pull the LCD and its casing away from the rest of the camera.
단계 4  ¶
  • Pull the LCD and its casing away from the rest of the camera.
