메인 콘텐츠로 스킵하기
도움말
Replacing Creative Zen X-Fi Battery
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
Remove the battery from the midsection plate that holds it and disconnect it from the power supply.
The battery stores the power that enables the device to run.
단계 1 Separating the Battery  ¶
Use a spudger to pry the battery from the midsection plate.
  • Use a spudger to pry the battery from the midsection plate.
  • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
단계 2 Disconnecting Power Supply  ¶
Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard. Hold the battery wires in place so that access to the soldering joints is not blocked.
  • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
  • Hold the battery wires in place so that access to the soldering joints is not blocked.
  • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
  • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
