메인 콘텐츠로 스킵하기
도움말
Sony Cyber-shot DSC-W55 LCD Screen Replacement
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
잘못된 도구
잘못된 도구
이미지 및/또는 텍스트의 올바른 도구를 사용하여 해당 안내서를 더 효과적으로 만들어 주십시오.
This guide will show you how to replace the LCD screen of the Sony Cyber-shot DSC-W55.
  • 작성자: Eddie Lo
  • 예상 시간 20 - 30 분
  • 난이도: 어려움
We will explain the steps needed in order to replace a LCD screen.
섹션
단계 1 LCD Screen  ¶
Verify the orange cables from the motherboard are removed from the LCD screen. Lift the LCD screen off the hinge. Lift the LCD screen off the hinge.
단계 1 LCD Screen  ¶
  • Verify the orange cables from the motherboard are removed from the LCD screen.
  • Lift the LCD screen off the hinge.
단계 2  ¶
Verify that the LCD screen is attached to the chip on the back on the camera. Remove the dial from the back of the camera. It pops right off very easily. Remove the screw using a Phillips #00 Screwdriver from the camera.
단계 2  ¶
  • Verify that the LCD screen is attached to the chip on the back on the camera.
  • Remove the dial from the back of the camera. It pops right off very easily.
  • Remove the screw using a Phillips #00 Screwdriver from the camera.
단계 3  ¶
Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force. Remove the chip and the LCD screen now from the camera.
단계 3  ¶
  • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
  • Remove the chip and the LCD screen now from the camera.
  • The chip may need a slight upward tug with a fingernail or tweezer.
