메인 콘텐츠로 스킵하기
도움말
Gateway MD2614u Processor Replacement
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
This guide shows you how to find the CPU and remove it from the laptop.
  • 작성자: Toni Pipes
  • 예상 시간 5 - 10 분
  • 난이도: 보통
You will use the fan repair guide to get to the CPU. Then, you will use the lock to remove the CPU.
단계 1 Processor  ¶
The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
단계 1 Processor  ¶
  • The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
  • You will hear a click as the lock unlocks.
단계 2  ¶
Place your fingers on opposite edges of the green card.
단계 2  ¶
  • Place your fingers on opposite edges of the green card.
  • Carefully lift the CPU upward.
