도움말
Parrot AR.Drone Teardown
분해도
분해도
분해도는 device의 내부를 보여주는 정보일 뿐 분해 설명서로 사용하면 안됩니다.
The AR.Drone is earth-shattering. It has blown away every drone expert we've talked to. It's not just a toy: it's a phenomenal piece of engineering that manages to solve some very difficult software problems in order to take flight. Hidden beneath the foam fascia lies some very sophisticated electronics, all of which makes flying the quadricopter very seamless. We were quite interested in seeing exactly what components Parrot used to make their awesome flying device.
This holiday season, let’s encourage repair and reuse rather than buying more things we don’t need and won’t last. With our friends at Wired, we’re running a toy repair contest. We’re giving away a ton of awesome tools, so make sure to get started on your entry right away!
단계 1 Parrot AR.Drone Teardown  ¶
The Parrot AR.Drone remote-controlled quadricopter recently landed on our teardown table. What's cooler than one quadricopter? Two quadricopters, of course! The AR.Drone comes with two hulls: an indoor unit with guards over the propellers (grey/white) and an outdoor unit (orange/blue).
  • The Parrot AR.Drone remote-controlled quadricopter recently landed on our teardown table.
  • What's cooler than one quadricopter? Two quadricopters, of course! The AR.Drone comes with two hulls: an indoor unit with guards over the propellers (grey/white) and an outdoor unit (orange/blue).
  • You might notice the lack of a controller with this awesome gadget. That's because the controls are managed via an iPhone, iPod Touch, or iPad by using AR.Free Flight, an application available for download in the Apple App Store.
  • Android users can now enjoy the AR.Drone Android app from the Market!
단계 2  ¶
Talk about repair-friendly; opening up the AR.Drone doesn't even require a screwdriver. (Compare this with some recent devices we have torn down!) The hull is attached to the body by a pair of  magnets; one in the hull and one on the body.
단계 2  ¶
  • Talk about repair-friendly; opening up the AR.Drone doesn't even require a screwdriver. (Compare this with some recent devices we have torn down!)
  • The hull is attached to the body by a pair of magnets; one in the hull and one on the body.
  • Much of the AR.Drone's body is made of expanded polypropylene (EPP), a common substance that is both extremely light and easily manufactured into complex shapes.
단계 3  ¶
The 1000mAh 11.1V lithium polymer battery is attached via a connector, making it delightfully easy to remove. The second connector is a balance charge connector, which ensures that each of the three battery cells is charging equally, thus optimizing capacity and prolonging battery life.
단계 3  ¶
  • The 1000mAh 11.1V lithium polymer battery is attached via a connector, making it delightfully easy to remove.
  • The second connector is a balance charge connector, which ensures that each of the three battery cells is charging equally, thus optimizing capacity and prolonging battery life.
  • The battery contains a protection circuit module, which prevents it from discharging too rapidly, over charging, or short circuiting.
  • Parrot claims the battery will only last about 12 minutes after a full charge, which takes around 90 minutes. Taking your AR.Drone out to the park with only one battery won't get you much play time, unfortunately.
단계 4  ¶
Next, we turn to the underside of the quadricopter. After removing four T6 Torx screws, the lower plate can be lifted off to reveal the motherboard and navigation board.
단계 4  ¶
  • Next, we turn to the underside of the quadricopter.
  • After removing four T6 Torx screws, the lower plate can be lifted off to reveal the motherboard and navigation board.
  • The navigation board is connected to the motherboard by eight pins and comes out without any hassle.
단계 5  ¶
The two large mesh cylinders make up the ultrasound altimeter, which stabilizes the quadricopter within 6 meters of the ground. The back side of the navigation board contains the Microchip PIC24HJ16GP304 40MHZ 16-bit microprocessor.
단계 5  ¶
  • The two large mesh cylinders make up the ultrasound altimeter, which stabilizes the quadricopter within 6 meters of the ground.
  • The back side of the navigation board contains the Microchip PIC24HJ16GP304 40MHZ 16-bit microprocessor.
  • The MEMS gyroscope, the Invensense IDG 500, is also found on this board.
단계 6  ¶
Front of motherboard: Parrot 6 ARM9 468 MHz processor.
단계 6  ¶
  • Front of motherboard:
  • Parrot 6 ARM9 468 MHz processor.
  • ROCm Atheros AR6102G-BM2D b/g Wi-Fi module.
  • Micron OGA17 D9HSJ
  • Vertical camera.
  • USB/serial port connector
  • On the back:
  • Micron 29F1G08AAC
단계 7  ¶
Each propeller assembly is made up of the  propeller blade, gear, motor and motor controller board. These are not your run-of-the-mill propellers. The design team behind these won a micro drone design contest put on by the French Army.
단계 7  ¶
  • Each propeller assembly is made up of the propeller blade, gear, motor and motor controller board.
  • These are not your run-of-the-mill propellers. The design team behind these won a micro drone design contest put on by the French Army.
  • The propellers spin in different directions depending on the side they are mounted on, and are marked either C (clockwise) or A (anti-clockwise).
단계 8  ¶
The propeller blade and gear are held in place by a small circlip on a stainless steel shaft.
단계 8  ¶
  • The propeller blade and gear are held in place by a small circlip on a stainless steel shaft.
  • Parrot sells a special circlip removal tool, but we opted for a pick we had lying around the office.
  • These little guys can definitely go flying if you're not careful. Luckily, they come as part of two different replacement parts packages available directly from Parrot.
단계 9  ¶
The four motors and their electronic controllers are each held to the central cross by six screws and a connector. Each brushless motor runs at 28,000 RPM while the AR.Drone is hovering, and as fast as 41,400 during full acceleration.
단계 9  ¶
  • The four motors and their electronic controllers are each held to the central cross by six screws and a connector.
  • Each brushless motor runs at 28,000 RPM while the AR.Drone is hovering, and as fast as 41,400 during full acceleration.
  • The speed of the motor is managed by the electronic controller, which includes an 8-bit microcontroller and a 10-bit ADC.
단계 10  ¶
The arduous task of peeling the protection blister from the body reveals the camera ribbon cable and the second magnet that holds the hull in place. The arduous task of peeling the protection blister from the body reveals the camera ribbon cable and the second magnet that holds the hull in place.
단계 10  ¶
  • The arduous task of peeling the protection blister from the body reveals the camera ribbon cable and the second magnet that holds the hull in place.
단계 11  ¶
A little bit of prying and the front-facing VGA camera comes right off. The 93 degree wide-angle camera can stream its video and images directly to your iPhone, iPad, or iPod Touch.
단계 11  ¶
  • A little bit of prying and the front-facing VGA camera comes right off.
  • The 93 degree wide-angle camera can stream its video and images directly to your iPhone, iPad, or iPod Touch.
  • With a resolution of 640x480 pixels, we doubt anyone will be filming HD movies with the AR.Drone's camera.
  • With Augmented Reality, objects captured by the camera become part of the AR.Flying Ace game.
단계 12  ¶
The central cross easily pulls right out of the foam shell. The two sets of wires in the central cross are responsible for controlling and providing power to the four motors.
단계 12  ¶
  • The central cross easily pulls right out of the foam shell.
  • The two sets of wires in the central cross are responsible for controlling and providing power to the four motors.
  • The tubes of the cross are made of carbon fiber to save weight and provide plenty of structural rigidity.
  • The other plastic pieces are made of polyamide 6,6 (PA66), more commonly known as nylon.
  • Yes, there are different variations of nylon, but it's not necessary to explain the differences between condensation and open-ring polymerization right now. Let's just get back to tearing down the AR.Drone.
단계 13  ¶
Parrot AR.Drone Repairability: 9 out of 10 (10 is easiest to repair). The battery and upper case come off easily without removing a single screw.
단계 13  ¶
  • Parrot AR.Drone Repairability: 9 out of 10 (10 is easiest to repair).
  • The battery and upper case come off easily without removing a single screw.
  • Almost everything is attached via ribbon cable connectors and screws, making replacement much more feasible.
  • Parrot provides replacement parts and repair videos for common problems. Repair wouldn't be very easy without both of these.
  • The c-clips on each propeller assembly are very hard to remove without the correct tool.
  • It's a pain to reapply adhesive after removing all the adhered parts.
