메인 콘텐츠로 스킵하기
도움말
Dell Inspiron E1705 RAM Replacement
단계 다듬기
단계 다듬기
해당 안내서에는 불필요한 단계들이 있습니다. 단계들을 다듬어 더욱 간결하게 만들어 주십시오!
This repair guide includes a step by step process for removing and replacing RAM for a Dell Inspiron E1705 laptop computer. Each step has pictures to help breakdown the process.
  • 작성자: Evan Fairchild
  • 예상 시간 10 - 15 분
  • 난이도: 아주 쉬움
Please read the troubleshooting section before using this repair guide to take apart your computer. Many problems can be resolved without taking the computer apart.
It is important to remove the battery before following these instructions. It will ensure no electrical discharge to occur. If you are unsure at all about how to remove the battery please refer to the battery repair guide for this item.
단계 1 RAM  ¶
Turn the computer over, screen closed, so that the underside is showing Locate the two screws as shown and remove them.
단계 1 RAM  ¶
  • Turn the computer over, screen closed, so that the underside is showing
  • Locate the two screws as shown and remove them.
  • Use a small phillips head screwdriver
단계 2  ¶
Remove plastic cover carefully There will be two RAM sticks as shown Using your fingers, pull the sides apart that are holding the RAM in place.  This will release the RAM.
단계 2  ¶
  • Remove plastic cover carefully
  • There will be two RAM sticks as shown
  • Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
단계 3  ¶
Carefully remove old/damaged RAM sticks and replace with new ones.
단계 3  ¶
  • Carefully remove old/damaged RAM sticks and replace with new ones.
