메인 콘텐츠로 스킵하기
도움말
Dell OptiPlex GX260 Motherboard Replacement
This guide will show you how to remove the Dell OptiPlex GX260 motherboard.
섹션
단계 1 Motherboard  ¶
Disconnect the ATX power cable to the motherboard. Disconnect the P4 12V(4x2) power cable from the motherboard.
단계 1 Motherboard  ¶
  • Disconnect the ATX power cable to the motherboard.
  • Disconnect the P4 12V(4x2) power cable from the motherboard.
단계 2  ¶
Disconnect the front panel ribbon cable by gently pulling it straight up. Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard. Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
단계 2  ¶
  • Disconnect the front panel ribbon cable by gently pulling it straight up.
  • Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
  • Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
단계 3  ¶
Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard. Disconnect the  optical drive audio cable connector from the motherboard.
단계 3  ¶
  • Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard.
  • Disconnect the optical drive audio cable connector from the motherboard.
  • Disconnect the audio input/output cable from the motherboard.
단계 4  ¶
Lift the metal tab near the right corner of the motherboard. Pull the green tab toward the front of the PC to release the motherboard.
단계 4  ¶
  • Lift the metal tab near the right corner of the motherboard.
  • Pull the green tab toward the front of the PC to release the motherboard.
  • From the rear of the PC, push the ports in while lifting the motherboard up and flipping it away from you.
단계 5  ¶
Stand the motherboard up as shown. Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off.. Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
단계 5  ¶
  • Stand the motherboard up as shown.
  • Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
단계 6  ¶
Remove the screw at the rear of the motherboard. Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base. If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
단계 6  ¶
  • Remove the screw at the rear of the motherboard.
  • Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base.
  • If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
