도움말
Repairing Sony Cyber-shot DSC-W290 LCD
문법 검토
문법 검토
회원님 내면의 영어 교사를 인정하고 해당 안내서의 문법 향상에 도움을 주십시오!
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
This guide is shows you how to replace the Sony Cyber-shot DSC-W290's LCD screen.
This guide will teach you how to replace the Sony Cyber-shot DSC-W290's LCD screen.
섹션
단계 1 LCD  ¶
Rotate the LCD and its casing so that the screen is facing you. Gently pull the control panel downward, freeing it from the small metal clips. Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
단계 1 LCD  ¶
  • Rotate the LCD and its casing so that the screen is facing you.
  • Gently pull the control panel downward, freeing it from the small metal clips.
  • Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
단계 2  ¶
Lift the LCD away from the metal casing on the right side. Slide the LCD to the right and away from the metal casing. Carefully pull the ribbon-wire out of the opening in the metal casing.
단계 2  ¶
  • Lift the LCD away from the metal casing on the right side.
  • Slide the LCD to the right and away from the metal casing.
  • Carefully pull the ribbon-wire out of the opening in the metal casing.
단계 3  ¶
The LCD is now out of the camera.
단계 3  ¶
  • The LCD is now out of the camera.
