메인 콘텐츠로 스킵하기
도움말
MacBook Air 13" Late 2010 Display Assembly Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
Replace the display assembly on your MacBook Air 13" Late 2010.
  • 작성자: Andrew Bookholt
  • 예상 시간 30 분 - 1 시간
  • 난이도: 어려움
Use this guide to replace your MacBook Air's display assembly.
섹션
단계 1 Display Assembly  ¶
Gently de-route the antenna cables out of the channel cut into the upper case.
  • Gently de-route the antenna cables out of the channel cut into the upper case.
단계 2  ¶
Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
단계 2  ¶
  • Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
  • We intentionally have you leave the third screw in to aid in future steps.
단계 3  ¶
Open the display until it is perpendicular to the upper case and place it on a table as shown.
단계 3  ¶
  • Open the display until it is perpendicular to the upper case and place it on a table as shown.
  • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
단계 4  ¶
Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
단계 4  ¶
  • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
  • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
단계 5  ¶
Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly. Once the two display hinges have cleared the upper case, remove the display and set it aside.
단계 5  ¶
  • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
  • Once the two display hinges have cleared the upper case, remove the display and set it aside.
  • Keep track of the shims under each of the two display brackets. When installing the display, be sure a shim is installed under each display bracket (against the upper case) as shown in the second picture.
