메인 콘텐츠로 스킵하기
도움말
MacBook Air 13" Late 2010 Upper Case Replacement
Replace the upper case on your MacBook Air 13" Late 2010.
Use this guide to replace the upper case.
단계 1 Upper Case  ¶
Remove the single 2.7 mm T5 Torx screw securing the right speaker to the upper case.
단계 1 Upper Case  ¶
  • Remove the single 2.7 mm T5 Torx screw securing the right speaker to the upper case.
단계 2  ¶
Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case. Remove the right speaker from the upper case. Remove the right speaker from the upper case.
단계 2  ¶
  • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
  • Remove the right speaker from the upper case.
단계 3  ¶
Remove the single 2.7 mm T5 Torx screw securing the left speaker to the upper case.
단계 3  ¶
  • Remove the single 2.7 mm T5 Torx screw securing the left speaker to the upper case.
단계 4  ¶
Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case. Remove the left speaker from the upper case. Remove the left speaker from the upper case.
단계 4  ¶
  • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
  • Remove the left speaker from the upper case.
단계 5  ¶
Use the tip of a spudger to pry the microphone away from the left side of the upper case. Remove the microphone from the upper case.
단계 5  ¶
  • Use the tip of a spudger to pry the microphone away from the left side of the upper case.
  • Remove the microphone from the upper case.
  • Upper case remains.
단계 6  ¶
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
단계 6  ¶
  • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
단계 7  ¶
While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
단계 7  ¶
  • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
  • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
단계 8  ¶
Remove the following seven screws:
단계 8  ¶
  • Remove the following seven screws:
  • Six 1.6 mm Phillips screws securing the the trackpad to the upper case.
  • One 1.4 mm T5 Torx set screw near the front edge of the upper case.
  • During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the movable side of the trackpad has minimal play.
단계 9  ¶
Carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
단계 9  ¶
  • Carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
  • Remove the trackpad from the upper case.
